Use the Cardholders tab to review information about cardholders in the access control system.
Name |
Description |
Search cardholder |
Type the characters of a cardholder name and it appears in the list, if it exists. |
Name |
Lists the names of the cardholders retrieved from the access control system. |
Type |
Lists the type of cardholder, for example:
If your access control system supports adding/deleting pictures in the XProtect system, you can add pictures to the cardholders. This is useful if your access control system does not include pictures of the cardholders.
Name |
Description |
Select picture |
Specify the path to a file with a picture of the cardholder. This button is not visible if the access control system manages the pictures. Allowed file-formats are .bmp, .png, and .jpg. Pictures are resized to maximize the view. Milestone recommends that you use a quadratic picture. |
Delete picture |
Click to delete the picture. If the access control system had a picture, then this picture is shown after deletion. |
© 2019 Milestone Systems A/S
