Actions specify the behavior of the access control system in XProtect Smart Client, based on the configuration of the triggering events.
You can specify one or more actions related to:
Triggering events are from a specific access control unit or from a group of access control units.
Name |
Description |
Trigger Event |
Select from the list an event category that should trigger an action. The list includes built-in, plug-in and user-defined event categories. Select Access control event, to create a trigger based on specific access control events instead of an event category. Select External event, to create a trigger based on an input event in the XProtect system. Specify the input source in the Source field for each trigger. |
Source |
Select the source which the action affects. The options depend on the setting of the Trigger Event field. For event categories and access control events, select:
Click Other to select multiple doors, door access points or other units in the access control system.
For external event: Select the source from a list of events and input devices in the XProtect system. |
Time Profile |
Select the time profile in which you want the action to be performed if triggered. Configure time profiles as part of Advanced Configuration. |
Action |
Select the type of action:
For each action, specify action details. To set up multiple actions, click Add access control action. You can do this, for example, if you want different actions triggered by the same event depending on weekend vs. office hours. |
Add access control action |
Click to add and define actions as required. |
Action details |
Configure the parameters for an action: Display access request notification:
Go to PTZ preset:
Start recording:
System action:
Add command |
Select which commands that should be available as buttons in the access request notification dialogs in the XProtect Smart Client. Related access request commands:
All related commands:
Access control command:
System command:
To delete a command, click X on the right side. |
© 2019 Milestone Systems A/S
