This tab provides mappings between door access points and cameras, microphones or speakers. You associate cameras as part of the integration wizard, but you can change the setup at any time. Mappings to microphones and speakers are implicit through the related microphone or speaker on the camera.
Name |
Description |
Doors |
Lists the available door access points defined in the access control system, grouped by door. For an easier navigation to the relevant doors, you can filter on the doors in your access control system with the dropdown list box at the top. Enabled: Licensed doors are by default enabled. You can disable a door to free a license. License: Shows if a door is licensed or if the license has expired. The field is blank when the door is disabled. Remove: Click Remove to remove a camera from an access point. If you remove all cameras, the check box for associated cameras is automatically cleared. |
Cameras |
Lists the cameras configured in the XProtect system. Select a camera from the list, and drag and drop it at the relevant access point to associate the access point with the camera. |
© 2019 Milestone Systems A/S
