Map access points in the access control system with the cameras in the XProtect system, to show related video for events from the doors.
You can map several cameras to one access point. The XProtect Smart Client user is then able to view video from all the cameras when investigating events, for example.
The XProtect Smart Client user is also able to add one of the cameras when configuring Access Monitor view items.
Licensed doors are by default enabled. Clear the check box to disable a door and thereby free an access control door license.
© 2019 Milestone Systems A/S
