Enter the name and specify the connection details for the access control system you want to add. The parameters that you must specify depend on the type of system, but are typically the network address of the access control system server and an access control administrator user name and password.
The video management system uses the specified user name and password to log into the access control system for retrieving the full configuration.
The integration plug-in may also define secondary parameters which are not listed in the wizard, but you can change these in General Settings after setting up the integration. The default values for the parameters are supplied by the plug-in or the XProtect system.
© 2019 Milestone Systems A/S
