Name |
Description |
Enable |
Systems are by default enabled, meaning that they are visible in XProtect Smart Client for users with sufficient rights and that the XProtect system receives access control events. You can disable a system, for example during maintenance, to avoid creating unnecessary alarms. |
Name |
The name of the access control integration as it appears in the management application and in the clients. You can overwrite the existing name with a new one. |
Description |
Provide a description of the access control integration. This is optional. |
Integration plug-in |
Shows the type of access control system selected during the initial integration. |
Last configuration refresh |
Shows the date and time of the last time the configuration was imported from the access control system. |
Refresh configuration |
Click the button when you need to reflect configuration changes made in the access control system in XProtect, for example if you have added or deleted a door. A summary of the configuration changes from the access control system appears. Review the list to ensure that your access control system is reflected correctly before you apply the new configuration. |
Operator login required |
Enable an additional login for the client users, if the access control system supports differentiated user rights. This option is only visible if the integration plug-in supports differentiated user rights. |
The naming and content of the following fields are imported from the integration plug-in. Below are examples of some typical fields:
Name |
Description |
Address |
Type the address of the server that hosts the integrated access control system. |
Port |
Specify the port number on the server to which the access control system is connected. |
User name |
Type the name of the user, as defined in the access control system, who should be administrator of the integrated system in XProtect. |
Password |
Specify the password for the user. |
© 2019 Milestone Systems A/S
