Add hardware: Scanning options
Choose where you want your system to scan for cameras and devices.
By default, the Scan local network checkbox is selected, which means that you only scan your local network for devices. However, if you know the IP address or a range of IP addresses to which cameras and devices are attached, specify these by clicking the Plus icon next to Add the IP addresses or IP ranges to be scanned. You can add more than one range of IP addresses if you need to.
© 2019 Milestone Systems A/S
