The use of XProtect Access requires that you have purchased a base license that allows you to access this feature within your XProtect system. You also need an access control door license for each door you want to control.
You can use XProtect Access with access control systems from vendors where a vendor-specific plug-in for XProtect Access exists.
Available functionality depends on the system you are using. See the Product comparison chart for more information.
The access control integration feature introduces new functionality that makes it simple to integrate customers’ access control systems with XProtect. You get:
In XProtect Smart Client, the operator gets:
Apart from a base license and access control door licenses, you need a vendor-specific integration plug-in installed on the event server before you can start an integration.
The maximum number of doors that you can integrate with XProtect Professional VMS Products is 1000. If more doors are available in the configuration that you import from your access control system, the integration stops.
© 2019 Milestone Systems A/S
