Investigations settings
You can enable investigations so that people can use the XProtect Mobile client or XProtect Web Client to access recorded video and investigate incidents, and prepare and download video evidence.
Name |
Description |
Investigations folder |
Shows where your video exports are saved on your hard drive. |
Limit size of investigations folder to |
Enter the maximum number of megabytes that the investigations folder can contain. Default size is 2000 MB. |
View investigations made by other users |
Select this check box to allow users to access investigations that they did not create. |
Include timestamps for AVI exports |
Select this check box to include the date and time that the AVI file was downloaded. |
Used codec for AVI exports |
Select the compression format to use when preparing AVI packages for download. The codecs you can choose from can differ, depending on your operating system. If you do not see the codec you want, you can add it to the list by installing it on the computer where the XProtect Mobile server is running. |
Keep or delete data when exports fail (MKV and AVI) |
Select whether to keep the data that was not successfully prepared for download in an investigation or delete it. |
Investigations
Name |
Description |
Investigations |
Lists the investigations that have been set up so far in the system. Use the Delete or Delete all buttons if you no longer want to keep an investigation. This can be useful if, for example, you want to make more disk space available on the server. |
Investigation details |
To delete individual video files that were exported for an investigation, but keeping the investigation, select the investigation in the list. In the Investigation details group, click the delete icon to the right of the Database, AVI, or MKV fields for exports. |
© 2019 Milestone Systems A/S
