The following table describes the settings on this tab.
General
Name |
Description |
Server name |
Enter a name of the XProtect Mobile server. |
Description |
Enter an optional description of the XProtect Mobile server. |
Mobile server |
See the name of the currently selected XProtect Mobile server. |
Login method |
Select the authentication method to use when users log in to the server. You can choose between:
Features
In this section, you control the availability of XProtect Mobile features.
Name |
Description |
Enable XProtect Web Client |
Enable access to XProtect Web Client. This feature is enabled by default. |
Enable all cameras view |
Include the All Cameras view. This view displays all of the cameras that a user is allowed to view on a recording server. This feature is enabled by default. |
Enable actions (outputs and events) |
Enable access to actions in XProtect Mobile client or XProtect Web Client. This feature is enabled by default. If you disable this feature, the client users are not able to see output and events even if they are configured correctly. |
Enable keyframes |
Stream only keyframes when users stream video on mobile devices or in XProtect Web Client. This uses less bandwidth. |
Deny the built-in Administrator role access to the XProtect Mobile server |
Enable this to exclude users assigned to the built-in administrator role from accessing video on XProtect Mobile client or XProtect Web Client. |
Log settings
You can see the log settings information.
Name |
Description |
Log file location |
See where the system saves log files. |
Keep logs for |
See the number of days to keep logs for (default is three days). |
Configuration backup
If your system has multiple XProtect Mobile servers, you can use the backup function to export the current settings, and import them on other XProtect Mobile servers.
Name |
Description |
Import |
Import an XML file with a new XProtect Mobile server configuration. |
Export |
Export your XProtect Mobile server configuration. Your system stores the configuration in an XML file. |
© 2019 Milestone Systems A/S
