The default location of investigations is in the ProgramData folder. If you change the default location of the investigations folder, the existing investigations are not automatically copied to the new location nor are they deleted. To change the location where you save the investigation exports on your hard disk:
The Investigations location window opens.
Note: If you do not move the existing investigations to the new folder, you will no longer be able to see them.
© 2019 Milestone Systems A/S
