Available functionality depends on the system you are using. See the Product comparison chart for more information.
Specify the following server settings for SMS:
Serial port |
Select the serial port to use for your USB/3G modem. The list that allows you to choose ports shows open serial ports on the computer running your system. |
Speed |
The baud speed of your USB modem device. The default value is 9600 baud. Although you can set any custom value for the baud rate, Milestone does not recommend that you change the baud rate unless you are a highly advanced user. |
SIM card PIN code |
Specify PIN code for the SIM card inserted in the USB/3G modem. |
SMS encoding |
Different types of SMS encodings exist to accommodate various language needs in the world. Your system offers you the following options:
7-bit encryption allows you to use up to 160 characters per SMS, however it also limits the type of characters you can use. 8-bit encryption is the standard form of encryption with more special characters allowed. It allows you to use up to 140 characters per SMS. 16-bit encryption is necessary for non-Latin alphabet languages. Characters from, for example, Arabic, Chinese, Korean, Japanese or Cyrillic alphabet languages require 16-bit SMS encoding. If you use any of these languages in your organization, you must set your system to use 16-bit encoding. 16-bit has a limit of 70 characters per SMS. |
© 2019 Milestone Systems A/S
