Specify the following attachment settings:
Include images |
Select the check box to include still images in email notifications. When selected, each email notification includes one or more attached still JPEG images. Attached images includes images of before the incident, after the incident and the actual incident, with the incident that triggered the notification in the middle. Important: If your device does not record any images while the sending of notifications are turned on, no images are included in the email notification you receive. |
Number of images |
The number of images you want to include in the email. You can include between 1 and 20 images. |
Time between images (ms) |
Minimum time (in milliseconds) to be between each image. You can set any time range between 0 and 300 seconds (5 minutes). |
Embed images in email |
Select the check box to embed images directly in the email. |
© 2019 Milestone Systems A/S
