Available functionality depends on the system you are using. See the Product comparison chart for more information.
Specify the following message settings for SMS:
Enable SMS |
Enables the use of SMS notifications, allowing you to specify further properties. |
Recipient(s) |
Indicate the telephone number of the recipient. To send SMS to more than one recipient, separate the phone numbers with a semicolon. |
Message text |
Specify required message text for the SMS notification. Message text must only contain the following characters: a-z, A-Z, 0-9 as well as commas (,) and full stops (.). Note that camera information, date and time information are all automatically included in SMS notifications. |
Variables |
Click a link to include a variable to the notification. The options are:
Ignore similar messages for: |
Specify the number of seconds to ignore sending similar notifications. This function is to ensure that you do not receive too many notifications before you have solved the relevant problem. |
Use schedule profile |
Select the schedule profile you want to use. By default, you can choose between Always On, Always Off or choose Add new... to set up a custom schedule. |
© 2019 Milestone Systems A/S
