Motion detection settings are linked to the Recording properties settings for the camera under which you can enable and configure motion detection for the selected camera. Motion detection configuration is a key element in your system: your motion detection configuration determines when the system generates motion events and typically also when video is recorded.
Motion detection is enabled as default. Disabling it improves the CPU and RAM performance of your system, but can also affect your motion detection, event and alarm management.
Time spent on finding the best possible motion detection configuration for each camera helps you avoid unnecessary recordings. Depending on the physical location of the camera, it may be a good idea to test motion detection settings under different physical conditions such as day/night and windy/calm weather.
Before you configure motion detection for a camera, Milestone recommends that you have configured the camera's image quality settings, for example resolution, video codec and stream settings. If you later change image quality settings, you should always test any motion detection configuration afterwards.
In the following two tables, you can see the differences between enabling (table 1) and disabling (table 2) built-in motion detection for a camera.
Enabled motion detection
Recording properties setting |
Recordings |
Motion-based events |
Non-motion based events |
Sequences |
Always |
Yes |
Yes |
Yes |
Yes |
Never |
No |
Yes |
Yes |
No |
Built-in Motion Detection |
Yes |
Yes |
Yes |
Yes |
Built-in Motion Detection & Event or Event only |
Yes |
Yes |
Yes |
Yes |
Disabled motion detection
Camera's recording settings |
Recordings |
Sequences |
Always |
Yes |
No |
Yes |
No |
Never |
No |
No |
Yes |
No |
No |
No |
Yes |
No |
Built-in Motion Detection and Event or Event only |
Yes (depending on settings) |
No |
No |
Motion detection sensitivity
Motion detection is per default set up for dynamic sensitivity. However, you can also adjust the sensitivity level manually under Motion Detection properties.
Milestone recommends that you do not enable manual sensitivity because:
© 2019 Milestone Systems A/S
