Available functionality depends on the system you are using. See the Product comparison chart for more information.
Generating alarms based on analytics events is normally a three-step process:
As mentioned, a third-party VCA is most often required for supplying data to your system. Which VCA tool to use is entirely up to you, as long as the data supplied by the tool adheres to the applied formatting rules described in the Milestone Analytics Events Developers Manual. For more information, contact Milestone.
© 2019 Milestone Systems A/S
