Restore system configuration
- If you use the system on a server running any supported operating system, copy the content of the backed-up Milestone Surveillance folder into C:\Program Data\Milestone\Milestone Surveillance.
- If you backed up the file devices.ini, copy the file into C:\Program Files\Milestone\Milestone Surveillance\devices.
© 2019 Milestone Systems A/S
