Central Settings lets you specify the login settings required for an XProtect Central server to access the surveillance system in order to retrieve status information and alarms.
If you are a user of the MIP, this is also the dialog that lets you specify the login settings for the MIP to access the surveillance system.
© 2019 Milestone Systems A/S
