Analytics Events let you specify the following:
Enabled |
Enable the analytics event feature. |
Port |
Specify the port used by this service. Default port is 9090. Make sure that relevant VCA tool providers also use this port number. If you change the port number, make sure that VCA tool providers change their port number accordingly. |
Events allowed from: All network addresses or Specified network addresses |
Specify whether events from all IP addresses/host names are accepted, or only events from IP addresses/host names specified in a list: In the Address list specify a list of trusted IP addresses/host names that you want this service to recognize. The list is used to filter incoming data so that only events from certain IP addresses/host names are allowed. Both Domain Name System (DNS) and IPv4 address formats are allowed in the list. You have two ways of adding addresses to the list:
Import |
Click the Import... button to browse for the required external list of addresses. To import an external list, save the list in a .txt file format. Each IP address or host name must appear on a separate line in the file. |
© 2019 Milestone Systems A/S
