Registered services display the services installed and running on your system. It displays the following information about the individual services:
Name |
Description |
Enabled |
Indicates if the relevant service is enabled. |
Name |
The name of the service. |
Description |
A description of the service. |
Addresses |
The inside and outside addresses used by the service. |
You can change the inside and outside addresses for a service. To do this, click the Edit button and enter the relevant inside and/or outside addresses. Note that you cannot edit all services. You can delete a service registration from the system by clicking the Delete button. You are prompted for confirmation before the service is deleted.
© 2019 Milestone Systems A/S
