Active Directory® is supported in XProtect Professional only.
You can add client users in two ways. You can combine these if you need to.
Name |
Description |
Basic user |
Create a dedicated surveillance system user account with basic user name and password authentication for each individual user. |
Windows user |
Import users defined locally on the server or from Active Directory, and authenticate them based on their Windows login. |
You must define users as local PC users on the server and disable simple file sharing on the server.
Add Basic users
Add Windows users
Important: When a user who has been added from a local database logs in with a client, the user should not specify any server name, PC name, or IP address as part of the user name. Example of a correctly specified user name: USER001, not: PC001/USER001. The user should, of course, still specify a password and any relevant server information.
© 2019 Milestone Systems A/S
