You must install XProtect Smart Client on your computer before you can use it. Download XProtect Smart Client from the surveillance system server and install it on your computer.
Before you begin, visit the Milestone website and verify that your computer meets the XProtect Smart Client's minimum system requirements.
Install XProtect Smart Client from the management server
The wizard suggests an installation path. Normally, you can use the suggested installation path. However, if you have previously used add-on products, this path might not be valid anymore.
Install XProtect Smart Client silently
A surveillance system administrator can deploy the system or XProtect Smart Client to users’ computers by using tools such as Microsoft Systems Management Server (SMS). With this tool, you can build up databases of hardware and software on local networks. You can then use the databases for distributing and installing software applications over local networks.
To install silently:
To run a silent installation using the default values for all parameters, start a command prompt (cmd.exe) in the directory where the installation program is located and perform the following command:
XProtect Smart Client 2019 R1 Installer x64.exe --quiet
Your system:
Milestone XProtect Professional VMS Products 2019 R1 System Installer.exe --quiet
This performs a quiet installation of XProtect Smart Client or your system using default values for parameters such as target directory and so on. To change the default settings, see the following:
In order to customize the default installation settings, you must provide an XML file with modified values as input. In order to generate the XML file with default values, open a command prompt in the directory where the installation program is located and perform the following command:
XProtect Smart Client 2019 R1 Installer x64.exe --generateargsfile=[path]
Milestone XProtect Professional VMS Products 2019 R1 System Installer.exe --generateargsfile=[path]
Open the generated arguments.xml file in a text editor and perform any changes needed. Then perform the following command in the same directory to run a modified version of the silent installation.
XProtect Smart Client 2019 R1 Installer x64.exe --arguments=[full path]args.xml --quiet
Milestone XProtect Professional VMS Products 2019 R1 System Installer.exe --arguments= [full path]args.xml --quiet
© 2019 Milestone Systems A/S
