After you install the Milestone ONVIF Bridge, the ONVIF Bridge service is running and the ONVIF Bridge Manager tray icon turns green. The next steps are to:
Add Milestone ONVIF Bridge to the Management Application
Configure user settings for an ONVIF client
Before you can complete these steps, you must have already created a basic user in Management Application, or a Windows user for the ONVIF client. The user must be assigned to a role that has permission to view cameras and access the Milestone ONVIF Bridge. For more information, see Setting up Milestone ONVIF Bridge security controls. For information about how to set up a basic user in Management Application, see the Help for those programs.
To provide an ONVIF client access to your XProtect VMS, follow these steps:
The name of the ONVIF client user appears in the list of ONVIF user credentials.
© 2019 Milestone Systems A/S
