Names of hosts you use in connection with your VMS system must follow the Microsoft standard of naming. This means that all host names must only use the ASCII letters 'a' through 'z' (in a case-insensitive manner), the digits '0' through '9', and the hyphen ('-'). If you use country- or regionally-specific characters as part of a host name for a component you use with the VMS, you may not be able to establish a connection between the system and the host machine.
© 2019 Milestone Systems A/S
