The CSV file must have a header line (determining what each value on the following lines is about), and the following lines must each contain information about one hardware device only. The field names are case sensitive, so you should ensure that you have written the fields exactly as shown below.
For each hardware device, the following information is required:
HardwareOldMacAddress |
Used to find the device that is going to have its properties changed. This is a mandatory field that you must enter in order to be able to import changes to the configuration from a CSV file. |
HardwareNewMacAddress |
The new IP address for the hardware device. |
HardwareAddress |
The IP address of the hardware device. |
HardwarePort |
The port for the hardware device. |
HardwareUserName |
The user name for hardware device's administrator account. |
HardwarePassword |
The password for hardware device's administrator account. |
HardwareDriverID |
If cameras and server are offline: specify a HardwareDriverID for each hardware device you want to add. Example: ACTi ACD-2100 105 indicates that you should use 105 as the ID if adding an ACTi ACD-2100 hardware device. |
When you import changes, no hardware detection takes place and no hardware functionality is changed. For example, if you replace a PTZ device with a device that does not have PTZ functionality, the new device still lists as a PTZ device.
The following applies for the information present in CSV files:
© 2019 Milestone Systems A/S
