Use the Notifications tab to turn on or turn off system notifications and push notifications.
If you turn on notifications, and have configured one or more alarms and events, XProtect Mobile notifies users when an event occurs. When the app is open, notifications are delivered in XProtect Mobile on the mobile device. Push notifications notify users who don't have the XProtect Mobile open. These notifications are delivered to the mobile device.
For more information, see Set up sending notifications to mobile devices.
The following table describes the settings on this tab.
Name |
Description |
Notifications |
Select this check box to turn on notifications. |
Maintain device registration |
Select this check box to store information about the devices and users who connect to this server. The system sends notifications to these devices. If you clear this check box, you also clear the list of devices. For users to start receiving notifications again, you must select the check box, and the users must connect their devices to the server again. |
Registered devices
Name |
Description |
Enabled |
Select this check box to start sending notifications to the device. |
Device Name |
A list of the mobile devices that have connected to this server. You can start or stop sending notifications to specific devices by selecting or clearing the Enabled check box. |
User |
Name of the user that will receive notifications. |
© 2019 Milestone Systems A/S
