XProtect Access licenses
XProtect Access requires the following access control-related licenses:
- A base license for XProtect Access that covers an unrestricted number of access servers.
- An access control door license per door you want to integrate and control in XProtect Access. Two access control door licenses are included with the XProtect Access base license. All door licenses are automatically installed when you install your XProtect Access product. However, the installed door licenses are by default disabled which means that you must enable the doors that you want to use. You can only enable as many doors as you have door licenses for.
Example: You have five access control door licenses and you have added 10 doors. Once you have added five doors, you cannot select any more. You must remove some of your doors before you can add another door.
To find information about the current status of your access control door licenses, expand the Access Control node.
To buy additional XProtect Access base licenses or door licenses, contact your vendor.
© 2019 Milestone Systems A/S
