Select snapshots
When you configured the LPR initially with the Add LPR camera wizard, you also added snapshots. You can always add additional representative snapshots to improve the optimization of the configuration.
- Select the relevant camera.
- In the Recognition settings tab, click Snapshots.
- Capture snapshots from live video or import them from an external location. Click Next.
The system analyzes the snapshots you have selected for the camera.
- On the next page, approve or reject each of the snapshots. If the system could not recognize any license plates, click Previous to add new snapshots in a better quality. If the system still cannot provide correct recognitions, you probably need to change your configuration. Check that the camera is mounted and configured correctly.
- When you have approved all snapshots, click Next and close the wizard.
- On the Recognition settings tab, click Validate configuration.
© 2019 Milestone Systems A/S
