If your system runs of disk space while archiving, you can set up an automatic response. Two scenarios can occur, depending on whether the camera database drive is different from, or identical to, the archiving drive:
Same drive: Automatic moving or deletion of archives if drive runs out of disk space
If your system server is running out of disk space, and the archiving drive is identical to the camera database drive, your system automatically does a number of attempts to free up space. Most of these attempts will result in the loss of your data from archives or databases.
- or -
The difference ensures that very large disks are not necessarily considered to be running out of disk space just because they have less than 15% disk space left.
- or -
The difference ensures that very large disks not necessarily are considered to be running out of disk space just because they have less than 10% disk space left.
- or -
The difference ensures that very large disks will not necessarily be considered to be running out of disk space just because they have less than 5% disk space left.
When the system restarts your recording server after resizing the database, the original databases sizes are used, so you should make sure that the drive size problem is solved or, alternatively, adjust camera database sizes to reflect the altered drive size.
If the system performs the database resizing procedure, you are informed on-screen in XProtect Smart Client, in log files, and or in notifications (if set up).
Different drives: Automatic archiving if database drive runs out of disk space
In case the system server is running out of disk space, and the archiving drive is different from the camera database drive, and archiving has not taken place within the last hour, archiving automatically begins in an attempt to free up disk space. This will happen regardless of any archiving schedules. The server is considered to be running out of disk space if:
The difference ensures that very large disks are not necessarily considered to be running out of disk space just because they have less than 10% disk space left.
On the archiving drive, the system automatically checks that the space required for data from a camera to be archived plus 1 GB of free disk space per camera is available. If not, the archive drive's oldest data from the relevant camera is deleted until there is sufficient free space for the new data to be archived.
© 2019 Milestone Systems A/S
