The CSV file must have a header line (determining what each value on the following lines is about), and the following lines must each contain information about one hardware device only. For each hardware device, the following information is required:
HardwareAddress |
The IP address of the hardware device. |
HardwareUsername |
The user name for hardware device's administrator account. |
HardwarePassword |
The password for hardware device's administrator account. |
HardwareDriverID |
If cameras and server are offline: specify a HardwareDriverID for each hardware device you want to add. Example: ACTi ACD-2100 105 indicates that you should use 105 as the ID if adding an ACTi ACD-2100 hardware device. |
Existing configuration parameters that are not specified in CSV file remain unchanged. If a parameter value for an individual camera in the CSV file is empty, the existing parameter value remains unchanged on that camera.
You can store hardware device information in spreadsheets as found in, for example, Microsoft Excel to save the information as comma-separated values in a CSV file.
The following applies for the information present in CSV files:
Even though the CSV file format is generally ASCII only, Unicode identifiers are allowed. Even without Unicode identifiers, the entire file or even individual characters can be Unicode strings.
© 2019 Milestone Systems A/S
