Available functionality depends on the system you are using. See the Product comparison chart for more information.
You can archive to other locations than the default archiving directory. The archiving location you specify can be a local drive or a network drive. Archiving to a network drive can mean that archiving time varies depending on the available bandwidth on the network.
If you archive to a network drive, the regular camera database can only be stored on a local drive attached directly to your system's server.
© 2019 Milestone Systems A/S
