Available functionality depends on the system you are using. See the Product comparison chart for more information.
Name |
Description |
Enable Speedup |
The speedup feature lets you use a higher than normal frame rate if motion is detected and/or an event occurs. When you enable speedup, further columns for specifying speedup details become available. |
Frame Rate |
Speedup frame rate for viewing video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). The frame rate must be higher than the frame rate specified under normal mode. |
Time Unit |
Select the required unit for live and recording frame rates (per second, minute, or hour). Note that you can only select time bases that let you speed up frame rates. Example: If you have specified 15 frames per second in normal mode, you cannot specify 16 frames per minute or hour in speedup mode. |
Speedup On |
Schedule Only |
Select this option to speed up according to the camera's speedup schedule only. |
Start Event |
Select the relevant start event. The camera begins to use the speedup frame rates when the start event occurs. |
Stop event |
Select the relevant start event. The camera returns to the normal frame rates when the stop event occurs. |
Camera |
Click the Open button to configure detailed and/or camera-specific settings (such as event notification, PTZ preset positions, and fisheye view areas) for the selected camera. |
Live Frame Rate |
The required average frame rate for live video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). The frame rate must be higher than the frame rate specified under normal mode. If the camera supports dual stream and you have enabled dual stream, the Live Frame Rate column is read-only with the value Dual streaming. You cannot change this. |
Recording Frame Rate |
The required average frame rate for recorded video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). |
© 2019 Milestone Systems A/S
