Specify the following frame rate properties:
Name |
Description |
Frame Rate |
Required average frame rate for video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). |
Time Unit |
Select required unit for live and recording frame rates (per second, minute, or hour). Note that you can only select time bases that let you speed up frame rates. Example: If you have specified 15 frames per second in normal mode, you cannot specify 16 frames per minute or hour in speedup mode. |
Camera |
Click the Open button to configure detailed and/or camera-specific settings (such as event notification, PTZ preset positions, and fisheye view areas) for the selected camera. |
Live Frame Rate |
The required average frame rate for live video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). If the camera supports dual stream and you have enabled dual stream, the Live Frame Rate column is read-only with the value Dual streaming. You cannot change this. |
Recording Frame Rate |
Required average frame rate for recorded video from the camera. Select the number of frames, then select the time unit interval (second, minute or hour). The frame rate must be higher than the frame rate specified under normal mode. |
© 2019 Milestone Systems A/S
