Name |
Description |
Template |
The template can help you configure similar properties quickly. Say you have 20 cameras and you want to change the recording path, archiving path, and retention time for all of them. Instead of having to enter the same three pieces of information 20 times, you can simply enter them once in the template, and then apply the template to the 20 cameras with only two clicks. |
Apply Template |
Select which cameras you want to apply the template for. Use one of the two Set buttons to actually apply the template. |
Select All |
Click the button to select all cameras in the Apply Template column. |
Clear All |
Click the button to clear all selections in the Apply Template column. |
Set selected template value on selected cameras |
Apply only a selected value from the template to selected cameras. |
Set all template values on selected cameras |
Apply all values from the template to selected cameras. |
Camera Name |
The name as it appears in the Management Application as well as in clients. You can overwrite the existing name with a new one. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] |
© 2019 Milestone Systems A/S
