Specify details about the new hardware device:
IP Address |
The IP address or host name of the hardware device. |
Port |
The Port number on which to scan. The default is port 80. If a hardware device is located behind a NAT-enabled router or a firewall, you may need to specify a different port number. In such cases, remember to configure the router/firewall so it maps the port and IP address used by the hardware device. |
User Name |
The user name for the hardware device's administrator account. Many organizations use the hardware device manufacturer's default user names for their hardware devices. If that is the case in your organization, select "<default>". Do not type a manufacturer's default user name as this can be a source of error, trust that your system knows the manufacturer's default user name. You can also select other typical user names, such as admin or root, from the list. Type a new user name if you want a user name which is not on the list. |
Password |
The password required to access the administrator account. Some hardware devices do not require user name/password for access. |
Device driver
To specify which device driver to use for the new hardware device, you can:
- or -
When the right driver is found, the Serial number (MAC address) field displays the MAC address of the new hardware device. When done, click Next.
© 2019 Milestone Systems A/S
