Specify when each camera should be online. An online camera is a camera that transfers video to the server for live viewing and further processing. The fact that a camera is online does not in itself mean that your system records video from the camera (configure recording settings on one of the following pages). By default, cameras you add to your system are automatically online (Always on), and you only need to modify their online schedules if you require cameras to be online only at specific times or events. Note, however, that you can change this default as part of the scheduling options.
For each camera, you can initially select between two online schedules:
If these two options are too simple for your needs, use the Create / Edit... button to specify online schedules according to your needs, and then select these schedules for your cameras. This way, you can specify whether cameras should be online within specific periods of time, or whether they should start and stop transferring video when specific events occur within specific periods of time.
The template can help you configure similar properties quickly. For example, if you have 20 cameras and you want a particular frame rate on all of them, you can enter it once in the template, and then apply the template to the 20 cameras.
Name |
Description |
Apply Template |
Select which cameras you want to apply the template for. Use one of the two Set buttons to actually apply the template. |
Select All |
Click button to select all cameras in the Apply Template column. |
Clear All |
Click button to clear all selections in the Apply Template column. |
Apply template on selected cameras |
Apply the value from the template to selected cameras. |
© 2019 Milestone Systems A/S
