You can export the current configuration of your Management Application, either as a safety measure in order to have a backup file of your configuration, or as a clone allowing you to use a similar Management Application configuration elsewhere. You can, at a later time, import previously exported Management ApplicationManagement Application configurations.
Export Management Application configuration as backup
With this option, all relevant Management Application configuration files are combined into one single .xml file, which you can specify a location for. Note that if there are unsaved changes to your configuration, these are automatically saved when you export the configuration.
If you intend to set up an identical version of your surveillance system elsewhere, do not export your configuration as backup, since this may lead to the same device information being used twice, in which case clients may get the following error message: Application is not able to start because two (or more) cameras are using the same name or ID. Instead, export your configuration as a clone. When you export as a clone, the export takes into account the fact that you are not using the exact same physical cameras, etc. even though your new system may otherwise be identical to your existing one.
Note that there is a difference between this Management Application configuration backup and the system configuration backup done from the Milestone Surveillance folder because these are two different things. The backup described here is limited to a backup of the Management Application configuration. The type of system configuration backup done from the Milestone Surveillance folder is a backup of your entire surveillance system setup (including, among other things, log files, event configuration, restore points, view groups as well as the Management Application and XProtect Smart Client configuration).
Export Management Application configuration as clone
With this option, all relevant Management Application configuration files are collected, and GUIDs (Globally Unique IDentifiers, unique 128-bit numbers used for identifying individual system components, such as cameras) are marked for later replacement. GUIDs are marked for later replacement because they refer to specific components (cameras and so on). Even though you wish to use the cloned configuration for setting up a new similar system using similar types of cameras, the new system does not use the exact same physical cameras as the cloned system. When you use the cloned configuration later in a new system, the GUIDs are replaced with GUIDs representing the specific components of the new system.
After you have marked GUIDs for replacement, the configuration files are combined into one single .xml file, which you can then save at a location specified by you. Note that if there are unsaved changes to your configuration, they are automatically saved when you export the configuration.
Import previously exported Management Application configuration
The same import method is used regardless of whether the Management Application configuration was exported as a backup or a clone.
© 2019 Milestone Systems A/S
