Configure master and slave servers
Available functionality depends on the system you are using. See the Product comparison chart for more information.
- Expand Advanced Configuration, right-click Master/Slave and select Properties.
- Select the Enable as master server check box.
- Click Add to add a slave server.
- Specify slave server properties. When ready, click OK.
© 2019 Milestone Systems A/S
