Configure system, event and audit logging
Your system can generate various logs. To configure logging, do the following:
- Expand Advanced Configuration, right-click Logs and select Properties.
- Specify properties for your system logs, including the event log and the audit log. Administrators can only disable/enable audit logging. All other logs are compulsory.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
© 2019 Milestone Systems A/S
