When you configure hardware devices, specify the following properties:
Hardware name |
The name as it appears in the Management Application as well as in clients. You can overwrite the existing name with a new one. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] |
Video channel # enabled |
Enable/disable each of the selected hardware device's video channels. Many hardware devices only have a single video channel, in which case only one channel is listed. Other hardware devices, typically video encoder devices, have several video channels. |
© 2019 Milestone Systems A/S
