Available functionality depends on the system you are using. See the Product comparison chart for more information.
When you add manual events, specify the following properties:
[List of defined global events and cameras]  |
Contains a Global node and a list of all defined cameras. You can configure as many manual events as required, no matter whether they are global or camera-specific. A + sign next to the Global node indicates that one or more global manual events have already been configured. A + sign next to a camera indicates that one or more manual events have already been configured for that camera.  |
Event name  |
Specify a name. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] Some cameras only support event names of a certain length and/or with a certain structure. Refer to the camera's documentation for exact details.  |
Send e-mail if this event occurs  |
Only available if email notifications are enabled. Select if the system should automatically send an email when the event occurs. Recipients are defined as part of the email notification configuration. When using email notifications, remember the individual cameras' scheduling.  |
Attach image from camera  |
Only available if e-mail notification is enabled. Select to include an image, recorded at the time the event is triggered, in the e-mail notification, then select the relevant camera in the list next to the check box.  |
Delete  |
Delete a selected event.  |
Add  |
Add a new event. When Global or a specific camera is selected, clicking Add adds a new manual event. When a specific manual event is selected, clicking Add adds a timer event to the selected manual event.  |
Send SMS if this event occurs  |
Select if the system should automatically send an SMS when the event occurs. You define the recipients of the SMS notifications as part of the SMS notification configuration. When you use SMS notifications, remember that you may have set individual camera scheduling. The setting is only available if you have enabled SMS notifications.  |
© 2019 Milestone Systems A/S
