You can select the language/character set that should be used by your system's server and clients.
Character encoding/Language |
Select relevant the language/character set.
Example: Select Japanese if your surveillance system server is running on a Japanese version of Windows. If the clients you use to access the system also run on a Japanese version of Windows, the Japanese language/character set ensure that the correct language and character encoding is in the communication between clients and the server. Only XProtect Professional supports master/slave functionality. |
© 2019 Milestone Systems A/S
