Available functionality depends on the system you are using. See the Product comparison chart for more information.
When you configure video and recording, you can specify certain properties for many cameras in one go. Either in order to speed up things, or because the relevant properties are shared by all cameras rather than being specific to individual cameras.
You can also specify all of the Frame Rate H.264/MPEG4 properties individually for each camera using H.264/MPEG4.
Template |
The template can help you configure similar properties quickly. Say you have 20 cameras and you want to change the recording path, archiving path, and retention time for all of them. Instead of having to enter the same three pieces of information 20 times, you can simply enter them once in the template, and then apply the template to the 20 cameras with only two clicks. |
Apply Template |
Select which cameras you want to apply the template for. Use one of the two Set buttons to actually apply the template. |
Camera Name |
The name as it appears in the Management Application as well as in clients. You can overwrite the existing name with a new one. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] |
Dual Stream |
Allows you to check if dual streaming is enabled on the camera(s). Note that the information is read-only. For cameras that support dual streaming, this can be enabled/disabled as part of individual cameras' Video properties. |
Live FPS |
Select the camera's live frame rate per second (FPS). |
Camera |
Click the Open button to configure detailed and/or camera-specific settings (such as event notification, PTZ preset positions, and fisheye view areas) for the selected camera. |
Select All |
Click the button to select all cameras in the Apply Template column. |
Clear All |
Click button to clear all selections in the Apply Template column. |
Set selected template value on selected cameras |
Apply only a selected value from the template to selected cameras. |
Set all template values on selected cameras |
Apply all values from the template to selected cameras. |
Record Keyframe Only |
Keyframes stored at specified intervals record the entire view of the camera, whereas the following frames record only pixels that change; this helps greatly reduce the size of MPEG files. Select the check box if you only want to record keyframes. |
Record All Frames on |
Allows you to make exceptions if you have selected to record keyframes only.
Use the Configure events list located below the other fields to define events that suit your needs.
Start Event |
Use when recording on Event or Motion Detection and Event. Select the relevant start event. The camera begins recording all frames when the start event occurs. |
Stop Event |
Select the relevant stop event. The camera only stops recording keyframes when the stop event occurs. |
© 2019 Milestone Systems A/S
