When you configure video and recording for specific cameras, you can determine when to record audio. Your choice applies for all cameras on your system.
Enabled |
Speakers are by default enabled, meaning they can transfer audio to your system. If required, you can disable an individual speaker, in which case no audio is transferred from the speaker to the system. |
Speaker name |
The name as it appears in the Management Application as well as in clients. You can overwrite the existing name with a new one. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] |
© 2019 Milestone Systems A/S
