When you configure video and recording, you can specify certain properties for many cameras in one go. Either in order to speed up things, or because the relevant properties are shared by all cameras rather than being specific to individual cameras.
You can edit all properties on a white background. You cannot edit properties on a light blue background. Note that all of the Frame rate - MJPEG properties can also be specified individually for each camera using MJPEG.
© 2019 Milestone Systems A/S
