To remove the entire surveillance system, including the surveillance server software and related installation files, the video device drivers, XProtect Download Manager, XProtect Smart Client, the Event Server service and the XProtect Mobile server, from your server, follow the standard Windows procedure for uninstalling programs. See the Windows Help for more information.
You can also remove individual components, such as XProtect Smart Client and video drivers by using the standard Windows procedure for uninstalling programs.
Important: If you remove your surveillance system, your recordings are not removed. They remain on the server even after the server software has been removed. Configuration files also remain on the server. This allows you to reuse your configuration if you install the system again at a later time.
© 2019 Milestone Systems A/S
