The Recording Server service is a vital part of the surveillance system. Video streams are only transferred to your system while the Recording Server service is running. The Recording Server Manager informs you about the state of the Recording Server service. It also lets you manage the service.
In the notification area (the system tray), the Recording Server Manager's icon indicates whether the Recording Server service is running or not.
- A green icon in the notification area indicates that the Recording Server service is running.
- A red icon in the notification area indicates that the Recording Server service has stopped.
By right-clicking the icon, you can open the Management Application, start and stop the Recording Server service, view log files, and view version information.
Monitor System Status
Right-click the notification area's Recording Server icon and select Show System Status to get access to the Status window.
The Status window lets you view the status of the image server(s) and connected cameras. The status of each server/camera is indicated by a color:
Place your mouse pointer over a camera in the status window to view details about the relevant camera. The information appears as a pop-up and updates about every 10 seconds.
Resolution |
The resolution of the camera. |
FPS |
The number of frames per second (frame rate) currently used by the camera. The number updates each time the camera has received 50 frames. |
Frame count |
The number of frames received from the camera since the Recording Server service was last started. |
Received KB |
The number of kilobytes sent the by camera since the Recording Server service was last started. |
Offline |
Indicates the number of times the camera has been offline due to an error. |
© 2019 Milestone Systems A/S
