When you add Windows users, you import users defined locally on the server and authenticate them based on their Windows login. This generally provides better security than the basic user concept, and it is the method Milestone recommends. If you want to include users in groups, make sure you add required groups before you add users. You cannot add existing users to groups.
Add Windows users in two ways: One is through the Manage user access wizard. Alternatively, add Windows users this way:
the Locations... button.
Users added from a local database logging in with a client should not specify any server name, PC name, or IP address as part of the user name. Example of a correctly specified user name: USER001. Example of an incorrectly specified user name: PC001/USER001. The user should still specify a password and any required server information.
© 2019 Milestone Systems A/S
