Restore points allow you to return to a previous configuration state. Each time you apply a configuration change in the Management Application, a new restore point is created.
All restore points in the current and previous five sessions are stored and can be selected again. A new session begins each time you start the Management Application as well as each time you save the whole configuration. For sessions older than the last five sessions, only the latest restore point of each session is stored. With the Number of old sessions to keep field, you can control how many old sessions are kept.
When you select to restore a configuration from a restore point, the configuration from the selected restore point is applied and used once the services are restarted.
If you have added new cameras or other devices to the system after the restore point was created, they are missing if you load the restore point. This is because they were not in the system when the restore point was created. In such cases, you are notified and must decide what to do with recordings from the affected devices.
Note: When you select a restore point, you can see information about the configuration state at the selected point in time in the right part of the dialog. This can help you select the best possible restore point.
© 2019 Milestone Systems A/S
