Your system uses a number of default file paths. You can change the path of these if you need to.
Default recording path for new cameras |
All new cameras you add use this path by default for storing recordings. If required, you can change individual cameras' recording paths as part of their individual configuration, but you can also change the default recording path so all new cameras you add use a path of your choice. |
Default archiving path for new cameras |
All new cameras you add use this path by default for archiving. If required, you can change individual cameras' archiving paths as part of their individual configuration, but you can also change the default recording path so all new cameras you add use a path of your choice. Note that camera-specific archiving paths are not relevant if you use dynamic path selection for archiving. |
Configuration path |
The default path used for storing your system configuration. |
© 2019 Milestone Systems A/S
